ph 2 172 timing pulley info question.
Changing the timing belt and pulleys on my 2002 172 next weekend.
can someone who knows tell me if the 172 engine has solid cam pulleys or were they fitted with the de-phaser pulley.
Basically trying to undestand if i will only need to lock the camshafts from the rear (through the blanking holes) or will i need to lock the cam pulleys as well.
any info appreciated.
  lift number 1 @ btm
You need to lock everything, and only the renault tools will do!
Do a search on here, it's covered almost daily.
