ph 2 lights
thinkin of puttin them on my ph quick is it hard to re wire them?
also my temp guage is reading really high is their anything that can be done to it?
Its not hard at all, there is a guide at www.fubarnet.com
How high is it reading, have you checked the coolant levels, also check the fan is working. Run the car at idle and when the engine reaches over the half way mark on the temp gauge the cooling fan will come on, iirc its variable speed and will start to come on above 99degrees and go off until the engine reaches 96degres.
