The car has been on the drive since december,it was fine when i parked it up other than a front wheel bearing needs replacing
the other day it moved it into the garage to fix said bearing and the abs/serv light came on after a few minutes
the pedal switch seemed to be the obvious choice when i googled it so iv tried following the guide to adjust it-the plunger pulls out easily (other poats suggest they need alot of force?) And as soon as its refitted the pedal clicka the switch all the way back in
should it be that easy?
Am i looking at a much more serious issue ?
