PH1 172 Idle Reving
Have a bit of a problem, my 172 has started idling wierd, when the car is cold everything is fine, it only when it gets up to temp when i put the clutch in and just sit idle the revs sit at 2k and bounce between 1.5k and 2k.
Otherwise the car is 100% and drives fine, its just when i the cars idle the revs just sit at 2k.
1st thought was idle control valve?
Any ideas?
Any ideas?
Hi im not an expert but had a similar problem on a car of mine! it was the Air flow meter! i do know when a cars engine is up to temp, if its "hunting" technical term lol! its runnig rich on the fueling! could be an air leak in a hose on the induction side also! ECU senses extra air and adds extra fuel!
Sorry cant be more help!
Lee
Any ideas?
It's telling you sell me and buy a 225 mate! Seriously tho sounds like a Air Flow sensor. Did you get her sorted? My 1st thought wud be idle control valve, but that wud cause the revs to be out whether hot or cold!
