ph1 172 throtle cable?
Car  clio mk2 ph1 172
today a i was cleaning out my throtle body and noticed that where the throtle cable is there is a clip and you can adjust where the clip goes,
i pulled it off and moved it a few notches to the left which moved the throtle ped up, it feels better being a tad higher but was wondering if moving the clip over just moves the pedal position or does it affect anything else?
any help would be great cheers
Awesome, never knew this, Cheers Danny
My pedals sit like this --_ althought the clutch is actually lower than that so they all kind of sit \ but not as steep lol!
If you remove the clip or put it to the end of the throttle side your throttle wont be WOT. Adjust the clip kickdown the pedal and check if the throttle WOT or not. I was runnig %76 throttle for a long time because of this!
So it is not for pedal adjustment, it is used to adjust WOT
it IS for pedal adjustment, you just have to make sure you get WOT
How should it be adjustetd then ? I'm assuming we're talking about the little rubber thing that you can click left & right on the right hand side of the TB ?
I messed with mine the other day when cleaning the butterfly valve, could I have adjusted it and not be getting wot ?
Adjust it with the clip so that your pedal's in a comfy position, and just have a quick check that when you have it fully depressed that the throttle body butterly is fully open. Simples.
ive just been and had another look at mine coz of what was sed bout WOT,
as you look at the engine its now 4 notches in from the the right which has taken a lot of slack out of the cable as it was rite at the end lol
