Ph1 clio 172 oil ---------- and service light
Car  ph1 172
Hey guys, came to my car this morning and started it as usual, waiting for oil ok to come up but it didnt! Instead i got oil------- and service light was lit up! Waited 30 seconds and milage came up! I checked oil level on dipstick wen i got to work! It was 3/4 in between min and max! Then thought to my self check it when its cold! So went to move the car but it wouldnt start and whilst turning it over the oil drum wiv drip light was flashing intermitantly! Im thinking i have a faulty sensor! But is it a oil pressure or oil level sensor and does anyone know if these can trip the engine managment into some kind of limp mode not allowing me to start car! Car did start again later on! So im puzzled! Could any of you advice me please
first was oil level that you saw on the display
the oil can light is oil pressure
check your oil pressure switch or check for any signs of leaking
No leaks mate! Do you know where i can find the pressure switch! The last fing i need is oil pump on its way out coz that may lead to seized engine!
