PH2 172 lumpy tickover and starting problems.
Car  A van
Ive had my PH2 172 for 2 weeks now and its got a lumpy tickover. It generally ticks over at 600rpm which is obviously too low and sometimes cuts out. Its also a bit of a t**t to start some times when warm, It'll try to fire, Fail, Then take about 10-15 seconds of cranking before starting, If i then knock it off it will fire with the 1st turn of the key thereafter.
The car is throwing up a fault code regarding the carbon canister but im assuming that wouldnt affect the tickover or staring.
Any ideas?
