ph2 lights
  Ph1 track 172
Does anyone have a picture of the back of these lights,
the side that you dont normally see,
because im very confused,
do the mk2 ph2's bulbs connect to the clusters a different way??
and do they not use the same bulb holder??
why does so much changing to the wiring have to be done??
basically, im swapping my ph1 rear lights with somebody for some ph2 lights
and i thought it would just be a snap off snap on job, (and just let the brake lights shine though the fog cluser as theyre both red):S
but it sounds to be alot more complicated,
not really bothered how long mine takes, but dont want to sit there for ages rewiring someone else lights because itll probably put them off swapping:nono:
They need to be re-wired.
yes the bulb holders are different.
Its a quick 10 minute job to re-wire them
  BMW 330ci Clubsport
I'm changing mine soon also (Thanks to Daniel for selling me his PH2 lights!), just waiting for the garage to be ready so I can get the car in (Complete mess atm, and wiring in this weather doesn't seem likea good idea).
Can anyone shed more light on how to get the wires out?
I know theres a clip or "cover" that goes over the pins, so after getting thet up what should I be doing? Pulling the wires towards where that clip was and through that gap in the plastic?
I'll post some pictures up of the wires and if someone could just draw on it with paint with what way to pull things or what way things should go that would be great!
