Phase 1 172 Rear Coil Springs....
Poopensharten
  Golf R
I had a cracked rear coil spring so i decided to replace the two of them for the sake of keeping wear and tear equal...
The springs that went on were a little bigger obviously due to being worn (or atleast so i think anyway)
Could someone whose running standard 15" OZ F1's check for me the distance from the bottom of the tyre in millimeteres to the top of the wheel arch on the paint work?
I measured both offside and near side and they gave readings of 645mm and 650mm so fairly close on the reading. It does seem to look a little higher than it did but could it be that the springs need to settle with time?
If someone could check id be greatfull.
Regards, Dan
