Phase 1 Inlets question
Hello,
Will a Phase 1 plenum mate up to the Phase 2 lower inlet, or do I need to buy the complete Phase1 plenum and lower inlet?
Regards Russ.......
Russ im sure that you can use the PH2 lower which can be the RS stamped one.
The upper i think has to be PH1 on a PH1.
Ah that's ok then, it's to go on the 172 Cup which is Phase 2 inlets, just looking to replace the top plenum as I've got the phase 1 cable TB., already converted from Drive By Wire, thanks for that.
Regards Russ.....
Hello,
Regards Russ.......
The ph1 plenum won't fit the ph2 unless you block the idle control valve hole by the throttle body mounting surface, otherwise the plenum i think is the same.
Yes cheers I know already in hand, car already has an AT unit on , just bigger than I thought and asked for, but won't go there.
Regards Russ.....
