Phase 1 Inlets question
Hello,
Will a Phase 1 plenum mate up to the Phase 2 lower inlet, or do I need to buy the complete Phase1 plenum and lower inlet?
Regards Russ.......
Mr R.
  A special one.
Russ im sure that you can use the PH2 lower which can be the RS stamped one.
The upper i think has to be PH1 on a PH1.
Ah that's ok then, it's to go on the 172 Cup which is Phase 2 inlets, just looking to replace the top plenum as I've got the phase 1 cable TB., already converted from Drive By Wire, thanks for that.
Regards Russ.....
  Odyssey 172 phase 1
Hello,
Regards Russ.......
The ph1 plenum won't fit the ph2 unless you block the idle control valve hole by the throttle body mounting surface, otherwise the plenum i think is the same.
Yes cheers I know already in hand, car already has an AT unit on , just bigger than I thought and asked for, but won't go there.
Regards Russ.....
