Ah that's ok then, it's to go on the 172 Cup which is Phase 2 inlets, just looking to replace the top plenum as I've got the phase 1 cable TB., already converted from Drive By Wire, thanks for that.
The ph1 plenum won't fit the ph2 unless you block the idle control valve hole by the throttle body mounting surface, otherwise the plenum i think is the same.
