Pictures of stripped loom
len_beach
  E92 M3,172 track car
(Poor) pictures of mine for anyone interested.
Airbag wiring, all unused plugs clipped back, heatshrink and the loom retaped.
You can just see the hazard panel on top of the clocks in the first pictures. I have also relocated the OBD port to where the heater rear screen button used to be.
The climate panel is sat on the pedals in the pictures as I had the heat gun out.
This is my stripped and extended rear loom. Speakers, aerial, hatch wiring and door sensors removed. Rather than splitting before the rear seats, everything now runs around the back of the car and then down the off side.
And a couple of cheeky shots of how she stands at present.
len_beach
Sick car :) good work on the loom mate
Loom looks really tidy. Good work
Cheers Guys. Hope you're making progress with yours Tommy.
So did you cut out everything that is not required?
I unwrapped and stripped the rear back to the plug and removed each pin. Extended it the re-wrapped.
I tried the same with the front but something didn't play ball so this time I cut the unused plugs up to the main loom leaving a 2cm leg if I needed to reattach the wire. Heatshrink then re-wrapped so you'd never know the plugs were there.
Although I've left redundant wires in the main loom, I didn't want to risk unwrapping the loom again and I reckon there's only 1kg between this and my fully stripped attempt.
  XC90, 330d, Trophy’s
i cant see the pictures from work Len, but ill have a good ol' look a bit later.
from the above comments, sounds as though you have done a good job tho, well done mate ;)
