Planning on pressure washing my car - Advice Needed
Car  BMW 323i Coupe
Came across a 1400W pressure washer in my house today, and thought about using it to clean the car at home. The only problem is that our outside tap does not work, so I'd need to run the water from the house.
Our hose pipe has a connector at one end, so that would connect to the pressure washer, so would I need to just buy another connector for the other end, and then a connector to allow a house tap to work?
If anyone does it using a house tap, any advice would be great.
im using an inside tap as i dont have an outside one. I just wrap a j cloth around the end of the connector thing and the tap and its fine, doesnt leak or anything...
you can buy the kit from B&Q, dont bodge it otherwise your asking for a mess.
go to b&Q they have a whole hose section, with ever hoselock an tap connector imagionable but they tend to be quite expensive, you would probably find a fix for the outside tap for the same price.
