if it was the starter motor surely the car would bump,
and if the crank sensor goes,
does it not still turn over??
when you say 'battery appears to be ok'
what does this mean??
as it might be ur alternator not charging the battery enuf
Hey Brembo.. you've got my coilpack but ive not received the payments yet?? At least a pm would be good to explain your delay mate.. i trusted you by sending the coilpack before the payments were cleared.. I am disappointed mate.
Do you want me to get you any bits off the clio here mate, as dean said, always plenty of them round baldovie scrappies
What you going to try next?
Have just tried using a positive lead on a running battery to the starter motor, spoke to a mechanic said this should start and then check if the starter motor works - anyone now if this is true?... didnt do anything, was bricking it aswell lol
Thanks Chris, I think im going to try and bump start it next then should get it for diagnostic check me thinks. Ahhh the joys :dead:
Well get one from a scrappy!!
DO NOT use renault to sort the prob, get the car back and we can change that saturday!
Throttle body - £700
Gutted.
I thought it would have still turned over personally
Any starting issues or immobiliser issues check the 3 black relays in the engine fuse box as these are very common for causing all sorts of issues.
