Please help guys ph1 172
Car  Mk1 16v brooklands
Right I've got nothing but problems at the mo..
1st problem! No radiator fan it's getting up near the red! But doesn't come on. I've replaced the thermostat, cts and 1 of the black relays. This has done fook all
The fan kicks in when the cts is unplugged, do I know te fan deffo has power
Problem 2! Temp gauge seems to be working ok! When I turn on the heater blowers or lights the temp gauge rises, but goes back down when turned off. Any ideas ??
Took tr bleed nipple off cranked it ad water came out
All pipes are getting hot!!
Rads getting hot!
Just no fan..
Replaced the new cts with the old one and the irratic needle movement has stopped, although it does still move the smallest amount when other electrics are used! Bit no where near as bad as before, maybe half a dot
