Hi all,
Firstly I’ve had a little search through the forum but can’t seem to find much on this issue.
I’ve recently picked up my first Clio Sport 172, all belts and pulleys have just been replaced by a specialist.
From cold the car starts fine from the first turn of the key. However, once it has warmed up and is restarted it is very slow to turn over. It may take a few attempts of 5-10 seconds and even when it does start up it is more of a ‘rumble’ than the ignition which you would expect.
I have had the spark plugs out (Bosch Super 4’s) and all seem in good condition. I have cleaned up the TDC sensor and the problem still persists. My next port of call was maybe the Coolant temp sensor?
Any advice would be greatly appreciated!
