Possible axle options?
Cro
Car  Meg'd r27
Trying to get the dash lights off the car, i think mainly because im still running drums on the rear after the conversion and it cant/wont cater for the abs/esp?possibly? Are there any other axles from other engines or models, 2.0L meganes etc that have the right sensors etc that I can use?? Cheers
Problem is 172/182 driveshafts on the front, and 1.2/1.4/1.5/1.6 drums on the back - amount of teeth on the driveshaft is different to the amount of teeth in the drum. Get a sport axle on it MATT BLACK sells them on here brand new.
Does it go off when you've stopped? and when you start/reverse off the drive light back up?
Speak to Adamhodg aswell for any advice, he has or did have the same problem, hes also done a conversion to a 2.0 not sure what his was to start with.
No comes on after a few minutes of driving. The stop and hanbrake light. Dont think i have seen it go off unless I switch off and on again.
Just get a 172/1.6 or any clio with rear disks.
Only reasonable option.
And yes its the reason for your problem all other conversions have it as well unless they chnage to proper disk or do some engineeering work.
