Power Figures
Hi all
I was just wondering (I’m a newbie when it comes to clios) is why they all make less than the quoted factory power? I’ve seen a few 172/182 and 197 at RStuning with full exhausts, and induction kits and still making less than the quoted power output. Why is this? Not to sound rude
JamesBryan
Hi all
A healthy one is usually not far behind, but those figures are PS, so 182PS not BHP.
PS is a few numbers higher than BHP.
R3k1355
Absolute wetter.
The engines aren't amazing in that respect, there's no beating about the bush. The engine is undersquare so doesn't rev all that well, which is kind of limiting for N/A. Compared to some other engines around at the same time, like the K20A it's certainly left wanting. Throw a load of money at it and watch it still fail to make power.
It's fairly reliable though and the car is still a hoot to drive, so worry less about numbers and enjoy it for what it is.
RichValver
  Clio 16v/172 daily
It just depends on if the cars timed correctly and looked after properly. Mines making above factory with just breathing/exhaust mods (172) 145k miles
thecrim22
  various
Just remember that dyno numbers are very hard to compare back to back as different dynos can read different numbers for the same car so many factors can alter the figures. The important part is the curve of the graph its self numbers only tell half the story
Martin_172
This!
when I used to go to rolling road days from here then generally the healthy 172s made high 160s and the healthy 182s made mid to high 170s, but of course that figure was really only good to let you know if your car was "about where it should be" as I'm sure on another rolling road you could be 10hp or more either side of it
  01RS,03 EP3,99 Evo 6
I only use my local Dyno Dynamics dyno. And my 172 PH1, wich has been serviced it´s whole life with 5000 km service intervals made 165 Hp and 202nm with panel filter in the std airbox, ported inlet manifold and 98 Ron. Everything besides that stock. Than installed the 182 manifold and only gained a litlte torque down .
From my experience , the 172 ph2 Cup has the better results when stock. It´s vary rare to see one stock below 170 on a DD dyno. Don´t know if the mapping is any different in stock form.
RichValver
  Clio 16v/172 daily
That's a good result! SRR typically read quite low (accurate?)
I'm told it's regarded as one of the more accurate rr yeah.
Iv taken a few of my cars there now and the figures seem to be about right
Clio 1.8 16v ~135bhp from factory
225 with filter and exhaust
