Power Steering Tank Relocation
So I have a breather tank for my ITBs to locate where the power steering tank is currently
question is where is best to relocate it tDrawing a blank with google images
JamesBryan
That would probably work.
Do you just want one because it's smaller?
JamesBryan
No I need to relocate the res from it's position so why not change it while it's off? I think the OE ones are a bit ugly myself, so a black one would also match my breather tank I have to fit (in the location of the power steering res)
Ahh right ok.
Where are you thinking of moving it to?
Under the strut bar where the fuse box is. Also can just run an inline filter from the rez to the pump if you want to use an aftermarket one. My advice is dont invest in the hpas because it will probably s**t itself and you'll go epas
  Clio RS ph2
Problem ze wspomaganiem kierownicy. Zainstalowałem elektryczny z Kangoo. pompa wodna jest również elektryczna.
