PowerCable help in 172
  Ziel Nurburgring
Hope you all had a gooe weekend! Anyway, Saturday afternoon and im on the drive trying to wire in amp etc. Dad asks how its going, "Easiest car ive ever tried to install" i reply! How wrong i was, the rcas and remote lead are in and easy to run but how the Funk are you supposed to get the power lead from the battery to the boot. The problem is getting from the cabin to the engine bay, i cant see anything in the bay.
Someone said about running it throught the same place as the bonnet release, but without ripping out the sound deadening and removing the radiator bottle and the brake fluid bottle(Ithink its that), how you supposed to do it?
yes, remove the bonnet release cable, drill through it, feed cable through, replace grommet
it really is easy
Drill through the bulk head stick your cable through then seal it. I used bathroom and kitchen seal, oh yeah then I covered the lot with no more nails. :D
  Clio 172 Ph2
On mine, the alarm cables had already been pushed through the bonnet release grommet so it was easy to just slide the 4 guage power cable through. You can stick you hand down inside the engine bay behind that cover and just pull the cable up. No need to remove anything.
Theres a hole under the steering wheel, at the back further up from the pedals. Well there is on my 1.2 anyway...
Just wrap the wire around a stick or somthing and hoy it through. It will pop up in ur engine bay
I used the same hole as bowman, found it very handy indeed as no drilling required, it just goes down the drivers side but you just run all the other stuff down the other side.
Pete
  Ziel Nurburgring
Was the easiest thing in the end. if you pull the carpet away the grommet is there on the on the left. All wired in and sounds fantastic. Recommend the MacAudio 225 for anyone wanting a little bass but not wanting to lose the boot space.
