Powershell/Exchange Management Shell scripts
.Joe
Good Afternoon There,
I'm having a slight issue setting up a script to produce user mailbox sizes, the command runs fine but for the life of me, i can't seem to get is running as a scheduled task/Powershell script.
the script is as follows:
get-mailbox –resultsize unlimited | get-mailboxstatistics | select-object DisplayName,TotalItemSize,StorageLimitStatus,LastLogonTime > mailboxsize.txt
Any help would be greatly appreciated,
Thanks in advance,
Joe
What error are you getting running as a script? By default the execution policy will not allow scripts to run. Check Get-ExecutionPolicy.
Good Afternoon Spoonie,
on our power shell the execution policy is currently set to RemoteSigned,
i can run the command manually, but its not going to be viable when the reporting goes live over multiple servers/
Joe
