pressure switch on aircon, help!!
Car  CLIO Iceberg 172
right guys whats the plausabilty that the presure switch (tri function pressure switch) on the aircon could fail....
i understand that this is the unit that tells my ECU to engage the compressors clutch when the air con button is pressed, if this is faulty then it could be the reasion that my aircon pump is not engageing.....
fully gassed and no leaks detected... could this be the problem...
renualt wanted £81.50p + vat for this stupid sensor.... personaly i cant justify spending that amount on a fancy bolt.....
so i need possible comformation that this is indead courseing the problem...
has anyone known of one of these to fail?
cant you order the part, try it, if it doesnt work takeit back, cleaned up of course!
as for you question im not sure! sorry
I could do but i really dont want to have the hassel and the enital layout... im gonna vist the scrappy on sat, see if i can grab a couple
