PS3 via DVI/VGA?
Pfft, would still expect it to work ;)
I have tried factory resetting the consol - because it was set up for 1080 res, and my monitor is 1050 so it wouldn't display anything anyway.
However, that lead is cringe worthy... £3?! Fooking hell, i'll try it anyway.
Cheers Kristian xxx
  Fiesta ST
Should work - says so in the description:
Q- I have a Play station 3 with HDMI and Samsung Synchmaster LCD TV with DVI connection, is the above product suitable for connection of HDMI cable into the TV''s DVI socket? - James Burns
Answer- Yes the product does support that.
Might be faulty? return and get another to be sure.
Can someone start up there PS3, and do everything you we need to press to change the res to standard... and share what you pressed? See if i can do it with a blank screen.
  Monaro VXR
Just press and hold the power button down for around 15 - 20 seconds. Will return the PS3 to standard settings.
Read the above posts.
My HDMI > DVI lead arrived today. Still no joy.
Its clearly because the PS3 is in 1080. And i think the reset trick has alot to live up to... because it isn't working.
Fark knows.
Someone right down the key strokes to manually select a lower res!
