Pure Motorsport Top mounts - Preloaded bearings questions.
  Many.
So I've had some Pure Motorsport solid top mounts on my daily DCi since November (Circa 20k miles) and I've recently noticed some odd noises from the front suspension. Had a few bits off tonight and noticed I have a visable amount of movement in the bearing (up/down mostly) so looks like I'm due replacement bearings.
However, I had the standard bearings when I purchased to start with, is it worth going for the pre-loaded bearings?
I believe these cause heavier steering, which tbh I'd quite like as I find the standard EPAS a little light sometimes.
Car is used daily, but also does about 10 trackdays a year.
Any advice is much appreciated
pure-motorsport Dan@SJM
Cheers :)
