Nope they have differetn hubs the Cup but had no effect it was juts a stronger hub.MRBILLYUK said:Don't quote me on this , but i'm pretty sure i read that the 172 cups and 182's have different hubs so giving it a wider track . Ask edde , he'll know .
Same ARB on both cars.Teds said:Don't 172's run the same wheel size eg. 16x7. so its just a 205 blown out onto the same rim..! its just gained in the offset then ..?
Also if the hubs are different in size. then driveshaft would be different as well...?
Just thinking of spec'ing up my 172. also is anti roll bar thicker on cup's.
If so, the track is only affected by wheel offset so the anti roll bar should be a straight swop.
What do you think...?
edde said:Nope they have differetn hubs the Cup but had no effect it was juts a stronger hub.
Differences etc are here.
http://www.cliosport.net/forum/showthread.php?t=161269
Suspension setup details for 172 and 182 and Cup here
The front is wider due to the camber being more.
Ie a 172 full fat front tyres look like this | |
A Cup look like this / \
I know I've not yet worked out how to tell pdf maker to use an A3 sheets of paper. Although I might have found out hoe you do it.BenR said:not exactly an easy to read pdf!
Nor does it explain the 10mm front track gain. The geometry changes just wont account for 5mm a side.
Yep read my link I posted above gives the different spec.AARON 61 said:Hi i know this is a bit of a different question but does that mean if you have four wheel alignment checked the garage would have to have the right spec for different spec models ie 172 different from 182 and different again from 182 cup wide track
cheers aaron
