Question re Britemax polishes/i4detailing
  A well built VW
I have the #1,#2,#3 polishes but i find they dust a hell of a lot compared to Menzerna I normally use.
I am applying as per instructions and via pc maybe using pad for 3 or 4 panels Any ideas before i bin em lol
Ta
  Megane 225 Cup
i notice that the megs tend to dust up quite allot and need to wash the car down again after use.. i keep spraying water onto pad to try and keep to a minimum or work on smaller areas.
Britemax compounds are a lot different to the Menz. They don't need to be worked quite as hard/long. They also prefer to be used on lower speeds. For a DA polisher use on speed 2 or 3 max. For rotary use no more than 2500rpm.
I was using #2 Resto Max recently on a very hot day and had no problems with dusting.
  PH2 172
My autoglym SRP gets ratehr dusty 2 been thinking about changing to a different brand anyone know of some good brands
  A well built VW
Ok thanks Matt I have been lessening the work time to reduce the dusting but ill give the speed thing a go see how i get on
  PH2 172
So SRP isnt a proper polish so what is a good brand to use seen some tropi stuff swirl and scratch remover is that any good or is that just for when u have scratches?
  A well built VW
Depends what you want a polish to do
I like this stuff carlack is good and durable will remove some of your swirls follow it up with some collinite wax 476 paste or 845 liquid wax and youll be fine for a good few months
