This is something that I will be having done very soon by a mechanically minded friend as I know nothing!!
Does the fact that it has ABS make any difference in the technique to bleeding the brakes?
My mate knows older Ford cars very well but hasnt actually bled brakes on an ABS model so im just checking that there is any other info I may need??
I have checked through the search button and found a guide where the person says to use 2L of fluid in the process to bleed the brakes, I only have 1L is that ok? Could someone give me a brief run down of what needs to be done on a 182 just so I dont encounter any problems along the way... Cheers
Rob.
Rob.
