quick answer please
  R35 GTR
Does the plenum thingy (bit with renaultsport) come on and off easy.
gonna start polishing tonight, and want to know if i need any special bits for refitting, like a gasket or sealant?
Off to halfords to get wet n dry now,
cheers.
Its called an inlet manifold *rolls eyes*
Will require a gasket, whether you can re-use the old one or not is debatable, personally i'd never re-use a gasket
bettwr pick up some auto-glm metal polish then! and also use a dremmel or same thingy to get the tight bits out! get some really rough sand paper,then a little smother ,then another and leave the fine fine one till last! then use the polish with a cloth wheel on dremel/buffer.
just got 1500 and 600 wet n dry from halfrauds, my arse hurts now. £8 fecking quid for 16 sheets!
got some autosol and a dremmel somewhere for finishing.
is it easy on and off for the whatsit then?
