Just as the title says please, just wanted something I could print off and take outside incase I forget anything. Like bolt/clip locations, how many I should undo and which ones to undo first etc etc
Got no pics but the 2 screw clips going into the bonnet need to come off, remove/get behing the arch linings in either side wheel arch, theres a 10mm bolt in each side holding the bumper to the wing area - infront of each wheel up high. Then underneath theres a few 10mm bolts holding the lower belly panel on the bumper on, then pull it out either side, and hold it from scratching the wings etc, and unplug the fogs, job done.
