Quick macromedia flash problem
Basically... got a menu with a button on it saying "enter".
On the action script ive got
stop();
so it stops at the menu instead of looping... but now when the user clicks enter I want it to goto a certain frame... ive tried adding
nextFrame();
but that means it doesnt stop at menu just loops to next frame... dont know if anyone has used Director but I just want to do some sort of "jump to frame command"
Cheers Daz
Its probably too late now (Quick macromedia flash problem) but i think this is what you need.
gotoAndPlay(FrameNumber)
or
if the frame you're jumping to is in a different scene
gotoAndPlay(SceneName,FrameNumber)
Hope this helps
Yea I cant find disable expert mode.. cos im trying to get it to normal mode... im using Flash 8 pro btw
oh its working now btw as well :)
code was:
on (release) {
gotoAndPlay(31);
I'm using Flash Version 6.
To quickly switch modes on this version you use
CTRL + Shift + E for Expert Mode
CTRL + Shift + N for Normal Mode
this only seems to work when you're focus is on the Actions frame.
