Quick question about 172's & non sports
I want to bring in the back wheels a bit on my 182 and I've been told the easiest way to do this is to get some 172 stub axles as they are thinner than the ones on a 182.
I'm just wondering if they can be found on non sports as well as there's plenty in my local breakers yard. I'm just not sure on the set up due as they don't have the disk and calliper set up on the rear.
Non sport rear setup is completely different. 1.6/DCi 100 have the same setup, but I believe stub axle thickness will be the same as 172's etc.
Thanks for the replies.
Yes I'm after the thinner stub axles. Hopefully there are some DCi's at the scrapyard then. Although I think they are all 1.2's.
I doubt you'll find a DCi 100, most of DCi's are 65/80 without discs.
