mailto:15.85sec@86.1mph">15.85sec@86.1mph- 1/4mile...0-60=7.21sec according to my gtech gadget. Supposed to be quite accurate so i will go by that. It was pretty consistant.
Clio 16v
21/04/2002
Avon Park
15.371
Exhaust and de-cat, K&N, Power boost valve
Clio 16v
25/08/2001
York Dragway
14.808
Hill Power induction kit with ram scoop, Magnex exhaust & decat, power boost valve, ecotek
Im thinking that Nick must have using Nitrous to get that 14.8.......
I dont know yet - ive never had it RRd and im hopefully doing my first 1/4 mile next month so will need to see! Just thought id see what the average times are...going by some of these times/mods im hoping for about 15s flat
Decated, straight-though exhaust, replacement filter in airbox, cams, HP chip and hopefully will have the PAS removed in time...also had it rebuilt about 20k ago. 1/4 mile is at Crail which im told isnt the most accurate (?) but im hopefull for a good time all the same - going by the weather up here itll be about 2 degree which should help! lol
Ive got pod print outs of high 15s but shes had a bit of work done since then and lost a bit of weight so will hopefully be ragging her at York soon, fingers crossed!
yeah the engine had, cams and a rebuilt balanced bottom end!
i had leather interior but took the rears out and parcel shelf and spare wheel for that day! i did have 16s on, and it was 30 degrees tho! maybe at york in the colder weather it would have maybe run a bit better.
the engine also needed cams timing and mapping as it was on standard cam timing and standard ecu.
the lad who bought it off me had the cams timed and it FLEW apparently! not sure if he is planning on getting it up the strip or not!
