rear arch liners snapped bolts
  Clio Trophy
Hello
so i removed the rear arch lines and the bolt snapped clean off, will i be ok to get some self tappers and make a small hole near the old ones? dont want to drill/screw into anything important
One of mine did this
I drilled straight through where it snapped off, then put a bolt through from the inside
Nut the other side, and you've got the stud back!
Then just apply arch liner with a new nut on top of that :)
Use a couple of washers as well
  Ph1
This happened to me a few weeks back. Currently got the same as above, drilled out with a bolt but going to get it properly welded in as its a bit pikey plus potential for dampness to get in the boot.
BTW Was down the scrap yard and noticed a few Ph2 1.2 Clio's were running a plastic nut / washer instead of using a steel nut to hold the liner in place. Far better idea
  phase 1 flamer 172
When this happened on my first 172, I welded a piece of stainless studding in, should out last the car.
  Clio Trophy
Hi,
just happened to to me damn it. Right if I drill straight through, how can I access it from the inner side. Could I see it from the boot?
obcuz
Yes, you can access it from the boot when you have removed the boot arch carpet.
Easy job with a bolt, make sure you seal it well inside and out to stop any corrosion.
Seems a common occurrence, I happened to me when I tried to remove one and I applied very little torque to the nut.
