so i removed the rear arch lines and the bolt snapped clean off, will i be ok to get some self tappers and make a small hole near the old ones? dont want to drill/screw into anything important
This happened to me a few weeks back. Currently got the same as above, drilled out with a bolt but going to get it properly welded in as its a bit pikey plus potential for dampness to get in the boot.
BTW Was down the scrap yard and noticed a few Ph2 1.2 Clio's were running a plastic nut / washer instead of using a steel nut to hold the liner in place. Far better idea
Yes, you can access it from the boot when you have removed the boot arch carpet.
Easy job with a bolt, make sure you seal it well inside and out to stop any corrosion.
Seems a common occurrence, I happened to me when I tried to remove one and I applied very little torque to the nut.
