Had a scraping noise coming from my rear brakes so my Dad has had a look while i was away.
Passenger side pads are worn down to the metal but drivers side looks fine. Extreme scoring on the the back of the passenger disk and he struggled to get the piston back using a windback tool, even with the piston back as far as he could get it he struggled to get the inner pad in so he had to grind some off to get the pad in to get the car home. Is it any easier to get the piston back with the caliper off?
I thought i needed new disks in the past so bought some without bearings in, but have access to bearing press. There is a bearing shop near me, or am i better buying the bearings direct from renault? Does anybody know the spec of the bearing i need?
Are there any guides etc on how to replace the rear bearings and disks? Any ideas of a rough cost from a garage?
Thanks in advance,
Scott
Thanks in advance,
Scott
