Rear brakes problem HELP!!!
  Nawt!!!Off road Quad!
Hi guys just put my car through a pre m.o.t (as it was a free be)
But not getting any reading off the footbrake for the rear brakes.But its given it off the handbrake...
Fitted new pads , had him blead them but still no reading im guissing its calipers ..
Any1 come accross this or now what it might be as i dont want to get calipers and its not them ?
Help would be much appreciated!
also dont think it could be a master as im getting good front brakes and also fluid was coming through when he blead them !
  53 Clio's & counting
have a search on the guides section mate im sure this is a known problem with the cups, dont think you need to replace anything,im sure its like that way std
seen one vosa reason about the load sensing valve which i was talking to the tester about and he's contacted vosa about that before because his mate was concerned... but there is generaly a problem with the rear brakes on my car as we had it on a 4 poster and with foot brake on we could spin the back wheels but with the handbreak we couldnt !
So dont know whether the h/brake cable is pulling the piston out that much further so dunno
  172 exclusive
the abs pump also control fluid control to the rear ,there might be a problem arising ,have you tried pressure bleeding the system ??
but surely that wont be the prob,as if the calipers wew not moving your brake pedal would feel like a sack of s**t?
yeh but the cable is pulling the handbrake maybe that extra bit is getting it to work ?
What else would you suggest to do ?
