Rear brakes - what to change?
Austin-182
as the title of the thread suggests, i want to know what is recommended when chaging the rear discs?
I will be using genuine Renault discs and pads, but i see some people also suggest changing the following;
Hub nuts
Spacer/washer
Retaining screw
Are the above necesarry?
Is there anything else to change?
Thanks in advance.
Chrisgti6
  MR2,TT V6,Swift,Mini
Hub nut would be worth doing, leave the washer and I don't know what the retaining screw is, but it's unlikely to be needed.
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
Hub nuts.
You can refit/re-use the little washers if in good condition , these can get flattened/deformed if they have been fitted wrong way round and over tightened
Austin-182
Cheers all.
I'm getting brembo HC discs and pads from George but want to go standard oe Renault for the rears.
Anyone know what the standard fluid is? I don't want to use the ATE stuff.
I will get the nipples if it's worth doing when changing the brakes as the fluid has never been changed before.
I did want to do this myself but really don't think It's wise incase I mess anything up.
