Rear Bumper Removal
Car  MK2 Clio
Looked through guides & search and have not found anything of help, I have a few questions to help a friend out about a rear bumper...
1 Where are the bolts to remove it,
2 How difficult is it to remove
Under rear wheelarches 10mm bolts,then the screws (torx bolts) bolts along the back after you open the boot.
No not at all.
As said.
Two bolts right up top underneath arch liners on each corner of the bumper (Will need to undo arch liners)
Two bolts underneath bumber in line with either side of number plate.
Two torx screws in top when you open boot.
