Rear Calipers - Rewind tool needed?
Car  RB FF 182
Hey guys,
Just got some new rear pads, but was informed not to bother fitting them untill I've sourced a caliper rewind tool.
Is it possible to push the piston back without having this tool? Is there an allen key/torx head in the centre of the piston that can be used also?
This is assuming the rear pistons are threaded?
Any help appreciated :)
Niall
I just use a Screw Driver is there are Slots in the Piston Head that a Screwdriver sits in nicely :)
Check out the fitting brakes thread in the Guide section Niall :)
Screwdriver should do the trick
