Rear (driver side) brake caliper
Are these easy to refurb?
Drivers side is sticking, not producing as much brake force as the near side one.
Though the piston goes in and out easy with the hand brake guessing it's mechanically operated as opposed to fluid when using the brake pedal.
Run through 500ml of fluid through all four calipers, not much different. Though exercising the piston (with no pads in carrier) seemed to produce more braking effort. No where near as strong as pax side.
