Rear roof scoops
stevo172-RWD
  clio 172 rwd
I was thinking about cutting two holes in the roof at the rear and fitting these twin naca ducts to add cooling to the rear .
I don’t want vents on the side of the car .
I do have some feeds coming off the rear side windows but I want more .
would want to fit them just before spoiler
R3k1355
How will this work? Where will the air go after it's hit the engine?
Seems like it'd work well, but you need to properly direct the air in and also the air out to make it most effective.
Also are you wrapping or ceramic coating all the exhaust parts to help keep temps under control?
stevo172-RWD
  clio 172 rwd
As the car moves air is drawn out the bottom and in any vents .
No no fancy wrap or coatings
