Rear seat belts
CTR
Car  Clio 2 rs
Hello,
i just remove rear seats and seats belts and unplug the connector from the seat belts, now is the airbag light on with the serv light..
Already try to wiggle the front cables under the seat but doesnt work..
I remove them beacause race car :p
Hello,
You've answered your own question. You disconnected the rear belt tensioners
yes i know but is there any plug to fit them connectors so that the light stays off?
On the 197,the wiring is behind the O/Side quarter panel in the boot.Pull the plug, fit 3.9 resistors fixed my problems.
My 182 has had the rear stripped in the past so it could be that some of the wiring was removed...
My 172 airbag light is on and when I used a code reader it said "rear airbag pretentioners" stripped the rear to check and there's no wiring there whatsoever. So I checked on eBay and some rear seatbelts have the wiring for it so I'm not sure what cars do and don't have the wiring tbh. Standard Renault thing to do tho really
