Rear seat question - help please :)
  Clio Campus Sport
hello just wondering if any one could tell me if the rear bench and backs (the split folding ones) from a 2004 clio would fit in my 1.2 06 campus sport, mainly because i want to have rear headrests and split folding seats as the 06 does not have them only one piece folding seats. also thinking about doing the fronts so they all match.
also would it be easy enough for a relatively competent mechanically sounded person to do lol??
cheers for any help
jezzy
I had a 2005 1.2 16v, and it came with a bench rear seat, and I swapped it for sport seats, which are obviously split folding seats, and all fitted fine.
Bolts at the back in exactly the same place, and the metal hook things that hold the front of the seat bit you sit on, I just had to cut slits in the carpet, the holes were already there. If this makes sense.
Also pretty easy to do. Remove Isofix bar (2 x 17mm bolt) then you'll find a torx screw bolt. Undo the rear one completely, loosen the front one, and the back comes off. Bottoms just lift up and unhook from where they hook in at the front.
