rear shims, where from and worth it?
Car  RS Clio 172 Phase 2
Lads,
im currerntly running 1.5 deg neg cambewr on the fronts with 0.5mm toe out either side.
its a FF172, on eibach sprtlines nad koni yellows are going in next week.
(Aus roads are bad for coilovers and they are way to exxy over here)
(try 2700 AUD for a set of KW variant 2's)
Is there any bewnefit on getting some rear shims to adjust the camber or toe and the rear nad what are ideal setting for a fast road clio?
you already have ideal fast road settings,
konis will give you more front camber, to save tyres go to 0 toe
regarding rear end, camber is fine, toe could go towards 0 for racing use, even toe out for slaloms but road use leave it as it is
