Rear shock
  Civic Type R, Clio 182
Hi all,
I used to use this forum quite alot but have bought a new car however my old clio 182 is still in the family (my mum drives it and averages 36mpg lol) and were having a few problems and would be grateful if anyone could help!
The car is on an 05 plate and has done 44000 miles and I'm less that happy with the reliability the car has been in 3 times for warranty work on exhaust including a new cat and is now booked in for osr wheel bearing, there's something wrong with the front strut (common problem?) and also have been advised that the knocking from the rear suspension is that the rear shock has failed and is leaking!:mad:
When i walked back into the service area with mecanic and he exlained what was need to the guy i was then told that the rear shock was not covered under warranty as its a wear and tear item!
I find this pretty bad its not covered and i seem to remember reading a thread along time ago about the same problem but cant find it.
has anyone else had their rear shock fail while the car was still in its warranty period and did they manage to get it fixed under warranty?
many thanks Harry
C
clvs2222
my rear shock is gone, as the guy said, its a wear and tear item. they are cheap enough if you shop around, £35+ VAT from german swedish french.
C
Cupster
I had that too. One leaking shock.
I was out of warranty anyway.
I replaced both rear shocks.
  Audi A3 TDI 170 B.E.
Welcome to the CLUB!!!!
They don't last long on all Clio's the shocks are a common proble after a while.
Could be the exhaust knocking the rear axle.
Front strut is it on full lock when your get a problem, if so you need the top washers changed. Try a search for this!
