Rear speakers in 182
Some cowboy (mention no name) cut the wires to the rear speakers out of my 182, to fit 6x9's instead. But now I wanna put the rear ones back in but he cut the wires too close to the connector which goes into the back of the speakers, anyone have any idea if reno sell the connectors so i can feed the wires into them or is there a way to take the old wire out of the connector so i can feed the existing wire into them.
Hope this makes sense
Why not just loop the wire through the hole in the connector and solder them. Much more reliable than any connectors.... if not normally a sweing pin can be used to release a locking pin which removes the metal part of the connector.
take a trip to halfrauds and go to the little bag section with all bits a bobs and get the semi-insulated crimp connectors in the sizes that you need.. 5 and 10 amp for either side iirc... and dont just run the wires through the whole in the connector.. agithegreat aka bodge it, leg it and run!
