Rear speakers
Car  Renault Clio 1.2 16v
Ive got some old 6x9's in my room which are collecting dust so was thinking about putting them into the clio's parcel shelf - yes i know they're crap and sound awful but they can't be much worse than the standard clio rear speakers :o
Is there a way of disconnecting the rear ones and running the cable to the rear shelf? How easy is it to do....?
Its pretty easy to do mate, if you have a 5door then just twist the speaker grill to the left I think it is or if its a 3 door the grill is attached to another bit thats attached to the panel. Just pull it off then unscrew and remove the speaker. The way I did mine was I cut the speaker wiring cos it wasnt long enough to go to the parcel shelf and I attached the wiring to other speaker wiring and ran it through to the boot.
It is easy enough, you'll just need some speaker wire to lengthen the existing wiring to the boot. 10min job.
As Above.... Easy as that just Crimp some Connectors on and run the Extra length to beneath the Parcel Shelf
there is any speakers in my "rear doors"(even thou its a 3 dr) or at the side of the parcel shelf??
