Rear strut brace that doesnt fit?
Car  350z GT
:S
Has there been any incidents before where someone has had a reat omp strut brace that doesnt fit??
literally it is too short to fit over both the metal cups on the car...too short by around 2 mm at least
any ideas??
cheers
ive had the very same problem but it wasnt with an omp one, it was as you say about 2mm too short, so i just drilled both the holes on either end of the brace a tiny bit bigger, job done
check the dimensions you have on the brace against what OMP state it should be to check they havent made an error! If the dims are right try jacking up one side slightly or park on the kerb and try and fit it. If its only 2mm it must be possible to squeeze it in! I'm no expert just what i would try before drilling.
thats what i would do.
Well, i wouldn't becuase rear strut braces are a complet waste of time and money, but you know what i mean ;)
what i have done it file some off the metal part on the car...fits lovely now :D covered it in grease and will see how the sqeaking is in the morning :D
cheers for everyones suggestions everyone
