rear trim removal?
hi guys, im wanting to remove my rear boot trim and spray it it. i have taken the 2 bolts out, 1 at either end, but now it sems stuck tight in the middle, is this another hidden bolt or is it that strong adhesive stuff (dont really want to pull on it until i know for sure)
any help appreciated
james
pretty sure theres 4 bolts mate 1 either end then 2 behind the motor thing that should still be accessable. 8 or 10 mils cant remember
yep there's 2 more torx screws in the middle, take off the plastic trim on the inside of the boot and poke the torx driver through. They're hard to see so you mostly have to work by feel.
Post pics after you've sprayed it mate, was thinkin of doing this myself.
i've done it to my mk1
easy job, fill and smooth the holes, primed, coloured then lacqured (sp?)
Hmm not too sure about the look of that, think I may prefer the carbon fibre effect.
